I’ve search through here and seen several other “Polishing Stainless” questions that you have answered (probably for the 1000th time) but I still have a question about what I should do/use for my particular project…
I’ve wet-sanded an item that is basically a 6d nail, going all the way up to grit #2000 and now I would like to polish it to the smoothest surface possible.
I was thinking that after the #2000 I could go straight to using a 6″ loose buff wheel with the White Rouge. Or would it still be best to use the “sisal, spiral, loose” with the suggested compounds combination?
OR 😀
Since it is such a small part would one of your Mini Buff 1″ pads (item 13140 A), the White Rouge and my dremel tool work better / just as well?
chknbone
