plasma cutter problem
- This topic has 0 replies, 1 voice, and was last updated 9 years, 2 months ago by .
I bought a versa cut last year, and I’m finally getting to use it. I set it up according to the manual, and I’m having a problem getting it to ignite. I checked all the connections, and the power supply(120 v) , but the igniter barely works. I took the tip apart, and it worked for about 2-3 minutes, then it got sporadic, to the point that it won’t ignite. Help!
