I had a painting question regarding using a reducer. when should it be used? I just finished painting my dash on my jeep using your eastwood single stage urethane paint. It turned out good but I got some orange peel effect I can live with it on the dash but want to see what I can do to reduce this effect when I paint the body. What has me more worried now is the temp has gotted hotter and I hear that could effect the flow, is this correct? So to sum up my long question is would a reducer help reduce the orange peeling effect and if so what would your recommend with your single stage urethane. thank you
