I am starting a new project and have questions. I am going to be painting a bare carbon fiber bicycle frame and would like to use the Dead Rat Flat Black. With this paint work? If so, will the Eastwood Epoxy primer be the best choice for primer?
As for sanding, what grit should I prep the bare carbon for primer? I will be hand sanding. What grit should i use to prep the primer for Dead Rat Flat? Will a clear coat be needed afterwards?
Thanks for all your help in advance, neewbie painter here.
