I’m restoring the grill on my 64 Chrysler 300. Some of the parts are plastic and are, what I would call them, argent silver. I’m thinking of using Eastwood’s Argent Silver Wheel Paint, https://www.eastwood.com/ew-rally-wheel-paint-silver-aerosol-12-oz.html, on these plastic pieces.
You da man when it comes to paint so none better to ask if this would be the correct way to finish these plastic pieces. Light sanding with some 120 grit paper, wipe down with a pre painting prep solution, then spray the Argent Silver. I’m open to any suggestions, and, if there is a better paint I could use for these pieces I’d sure appreciate that info too.
Thanks Kevin, in advance, for any info you might be able to give me.
