Order of Layers
  • #35783
    TheBeast
    Plan on sanding down my foxbody to bare metal. I’d like to use an epoxy primer initially but not sure the order of operation afterwards. Id like to get the car laser straight. What do I do next? Contour filler, block and sand, then color and clear? Or do I need to spray a high build primer over the contour before the color? This will be a slow project once the epoxy is sprayed not sure if that matters with moisture and the filler.
    Thanks in advance!
