Question, I mixed my eastwood epoxy primer wrong, i mixed 2-1 instead of 1-1. i sprayed 2 light coats before i realized my oversight. then corrected my mix. the primer was flashing between coats but the final (correct mix) seemed like it took long to dry. I know humidity and temp affects the curing time. I called eastwood and he said improper mix will definately slow down the drying time. any way to test to make sure all is good, I am going to let it sit until Saturday before I move the truck bed. Yes this is a home primer job, in a garage about 75 degrees and high Georgia humidity.
