Not sure you’ve made a continuous weld?
- This topic has 0 replies, 1 voice, and was last updated 17 years, 6 months ago by .
Looking for holes in welded seams is difficult and many don’t show up until you’ve ground down the weld bead. To make it easier on yourself, keep a light behind the panels being welded. The bright light will show through any holes in the joint, directing you precisely to where you need to add some weld.
