Hiya, I purchased a MIG 175 rig about 4 years ago and i’ve put roughly 150lbs of wire through it and other than needing some fine tuning and regular maintenance, the welder has performed quite well and I’m very happy with it.
The welder recently developed what I would consider it’s first “real” problem with the gas valve not closing/shutting off after I release the torch trigger, usually requiring a hard hit to the welder body fairly quickly to cut the gas flow and stop wasting the gas. The problem is intermittent and theres no telling when it will stick open.
I’ve been unsuccessful in finding where I can order the replacement gas valve online and was hoping someone could provide a part number or point me in the right direction of where I can order it.
Thank you
