need help on primers
  • #35918
    chevyman3872
    need some help on the differnt primers ,just starting the body work ,dont need much only 2 dents the rest is sanding once i get the dents out what primer should i start with want to do it in black ,because when i am done will paint ratrod black ,i am working in a 1986 camaro. will need all the info i can get the good and the bad all of it is a learning curve so i will take it all in thanks
