more rust and paint questions
  • #32249
    guys-
    i read thru the archives and back a bit into the oilder posts.
    i do alot of motorcycle frames.
    and i still have some questions.
    rust encapsulater-
    can it be used to “spot prime” so to speak?
    is it compatible with existing original finishes? or must the whole frame be stripped and encapsulated?
    is it sandable? and will it take the place of epoxy primer ? can poly primer be used over it?
    rust converter-
    what does it actually convert the rust into?
    how badly rusted is too far gone for rust conveter to convert? keep in mind i am talking about 1-2″ steel tubing motorcycle frames.
    thanks!
    -hacksaw
