magnet grounds
  • #30830
    BeeBob
    Has anybody tried using “earth magnets” or other types to hook the grounding clip to? If you don’t have a good “post” to clip to these might work…IF they don’t melt or give off some sort of gas. You could also just pull them off after coating, heat the part and put them back on for multi coats. Obviously you wouldn’t use plastic covered or painted….Thoughts??
