I have a ’66 mustang that has a very leaky cowl area. I already used a cowl repair kit that worked fine but I noticed that a lot of water is coming thru the flat metal under the outside grills. If you look under the dash you can see the water dripping thru the metal,must be alot of fine pinholes. Do you have a product that can be either sprayed thru the grills or srayed or brushed on under the dash to fix this problem. Thks Mark
