I would like to thank everyone for the welcome to the pc forum,I hope this does’nt sound stupid, on single stage powders is one coat enough, when should you use 2 coats? If the metal is pitted would this help or should I just use a metal filler? and then coat it? Also clear coat after part has fully cured spray clear right out of the oven and cure for how long?
