I’m curious about the IR curing system and it curing from the surface without having to heat the whole part up. I want to know if this might allow a FWD Transaxle to be coated without disassembly if you were to remove all the external gaskets and drain it of fluid. I’m concerned about the bearings and any internal seals that wouldn’t be removed.
Same question about a 4 cyl engine block?
I tend to think the engine block would be fine (even in a regular oven at 400F as long as all gaskets were removed)
