Internal Frame Coating and Epoxy Primer
- This topic has 0 replies, 1 voice, and was last updated 11 years, 6 months ago by .
I have a question about your Internal Frame Coating.
I am working on my frame rails, and have sandblasted and epoxy primed parts of the inner rails that I can get at. However there are parts that I just can’t get to. My though is to use your Internal Frame Coating for those parts. My question is about how well the Internal Frame Coating will play with the existing epoxy primer. There will be areas that are already primed, that will get a fair amount of the Internal Frame Coating on it. Will the Internal Frame Coating interact or cause any problems if it is sprayed over the epoxy primer?
What about other areas that will have the Internal Frame Coating that gets hit with epoxy primer on top of it (kind of the opposite of the first question)?
