Hi folks.
I see mentioned that the clear goes directly over the base color coat within 12-24 hrs. with NO sanding or other prep to the base coat for proper adhesion.
So, what about the slight imperfections in the finished base surface ? I feel sure there will be some. Slight orange peel, waves or other slight anomalies. Or is this last coat to be perfect ? or, does the clear make them invisible ?
Having no experience (yet) I would assume that the base would be sanded laser straight through 3000 grit and polished before the clear went on.
Evidently, I am missing something.
