It’s my metal prep. It’s not very effective and I don’t think I’m doing as good of a job as I need to.
Here’s what I currently do:
Aircraft Stripper to remove paint/powder coating
I’m having a hell of time getting ALL of the paint out of the small areas of valve covers with my plastic putty knife and this chemical.
I rinse it off, blow it dry and let it air dry as well.
Media Blast
I’m not a fan of this lately with the valve covers I have since the baffles are welded in and I don’t want to get abrasives in there.
Rinse in Pre or Acetone
I allow it to air dry
Coat
Now, I’m not using a parts washer and I haven’t been using my simple green bath on the aluminum parts. Should I be?
What else can I do for the valve covers so I don’t have to media blast them or do I have to and and just be really careful or something?
I know if I had an effective method, it would fix my issues.
Also, if you guys could recommend tools (parts washers) or tubs full of cleaner/strippers that you use, I would REALLY appreciate it.
Steve
