HVLP turbine?
Posted: October 11, 2005 By: 79bandit
  • #27635
    79bandit
    I am in the process of restoring a 79 Firebird, and although I am far away from the base/clear coats I would like opinions on the best system to use. I am fairly sure that my compressor will not cut it for the complete paint job, it will do fine for the primer coats but that is about it. From the research I have done, it appears that I would have to go with a 220v compressor to have the capacity that I will need. I have looked at several HVLP turbine systems that appear to be just what I need. Accuspray and Apollo seem to be the top choices, both are 3 stage systems. I would like to hear from anyone that has used this type of system to paint a car, and any pros/cons about hvlp turbines. :confused:
