Hvlp spray pattern setup
  • #35255
    Umm
    Ok getting ready to spray slick sand primer. I have a 2.0 tip hvlp gun. Watched your videos on gun setup. Shooting water to setup. I am getting the “barbell” spray pattern. I have tried making adjustments to the fan, fluid, and air. The regulator pressure at the tank reg is 60psi at the gun reg is 40psi-with trigger pulled full on it is at 20psi.
    Is the barbell fan pattern because the liquid is not thick enough for the 2.0 tip? In this case.
    Any other ideas?
    Thanks in advance.
