Hot & Humid
  • #34862
    backhalfman
    I purchased your epoxy primer & catylist to use on some work I had started on my wifes car but because it was so hot & humid I think it prolonged the dry time. I have a Sharpe HVLP gravity feed gun and was wondering what air pressure I should be using . I set my regulator at the Filter at 40psi and backed the air down to 25psi at the gun with the mini-regulator but when I was finished I did notice a few runs . Some time’s it’s hard to remember to put the gun down in between coats .. Can I use the featherfill G2 on top of your epoxy primer if I need to ?
