hi temp
- This topic has 0 replies, 1 voice, and was last updated 15 years, 5 months ago by .
All right. One or all of you powder masters please help me. If you are not woried about the hi temp stability of the hi temp powders “can you cure hi temp powders at 350 degrees and will it hold up like regular powder would”? I coated some heads with high temp orange. The customer wants the same powder put on his engine cases, but I can only cure the cases at 350degrees. Can I do this with hi temp??
