Help! Plasma cutter problem
  • #35450
    scarypat2001
    Hi,
    I just purchased a new Versa Cut 40 plasma cutter, and it’s my first experience with that kind of tool.
    I’m having problems cutting 1/8 steel. It actually barely etches metal, even at 40 amp, 60 psi. tried all kind of combinations, does not work at all… I’m far from getting the cutting results I see on most videos!
    I have what seems to be a nice pilot arc, and tried the instruction from a post explaining how to “break-in” the plasma cutter.
    For the steel itself: grinded to bare metal the cutting area and the ground patch, which I put less than 8 inches from the cutting area.
    For the machine:
    1) running on 220, single circuit with 40 amp circuit.
    2) air: got a small dryer at the exit of the compressor – will buy another dryer that I’ll put at the machine entry point, just in case.
    3) amps: tried everything from 20 to 40
    4) pressure: tried anything from 30 to 70 psi.
    5) did not change the nozzle yet – it has barely 30 minutes of trial, but will try that today.
    I saw a post from someone who had similar issues, but there was not conclusion…
