I coated the frame in HD Bead Blast, assembled the whole bike and then went to hose it down of the dust from sanding the KL primer on the tank the night before. Blew it off with compressed air and within 10 minutes the lower tubes of the frame under the motor started to flash rust, WTF. Has anyone run into anything like this before. I used some PB blaster on the engine cam cover and rinsed it off with brake cleaner, Matt thinks this may have been the problem, I just dont see how either of those items should affect the cured finish to make it rust so quickly. You can see the rust in this photo. BTW the seat cover got done today in 20 minutes while I waited, great service after they told me they were slammed with work.
