Getting ready to paint… questions.
Posted: March 5, 2012 By: 67RogueX-code
Home Forums Painting/Custom Artwork Getting ready to paint… questions.
  • #34203
    67RogueX-code
    I have completed all of the body work on my ’67 Rambler Rogue (rotisserie restoration), and have a bunch of questions.
    After completing all of the bodywork, I sprayed the entire body (inside, outside, underside) with Eastwood’s self-etching primer, and am planning on several coats of Featherfill G2 primer on all of the exterior panels, for block sanding.
    Question #1. Should I thin the Featherfill before spraying, and if so, how much, and with what?
    The final paint that I am going to use is Eastwood’s Single-Stage Urethane (Beach Bum Metallic).
    Question #2. Will I be ok to spray this over the self-etching primer… assuming I don’t Featherfill all of none exterior panels, such as the underside, wheel-wells, trunk, engine-compartment, etc. ?
    Thanks for your help.
    Bob Wilcox
    67RogueX-code
