Gator Guard thinner/solvent
  • #28811
    61tbirdcv
    I am considering using Gator Guard II as a undercoating for my 61 Tbird restoration. What is used as a gun cleaner? If I want to thin for better leveling what should I use?
    The body is mounted on a rotisserie. It will be media blasted prior to applying Gator Guard. Do I need to prime/seal before? If so, sould I use an epoxy primer? If my understanding is correct Gator Gaurd contains epoxy at what percent?
    Seam sealer – is it recommended to seal the seams prior to applying Gator Guard? If so, which is the very best? What should be the wait time before applying the Gator Guard?
