Fluidizing Attachment
  • #30201
    WiseGuyz
    I’ve got and Eastwood Pro 1100 powder gun and recently purchased the Fluidizing Attachment for it. Normally, I’ve been running between 10 and 15 lbs of air pressure to the gun and I’m wondering if I need to increase pressure to between 15 & 20 lbs for the attachment to work correctly, or if the lower pressures will still be ok. I don’t like using more pressure than necessary, especially for second coats where the powder tends to blow off more easily if you get too close.
    Dan
