I am redoing a 1955 f100 with my son, Eastwood Rat Rod Black to be color. We are working on the cab interior, removed windows, doors, weatherstripping, stripped and sanded the dash and all the hard to reach areas around the window areas,etc. Stopped the work for a couple weeks, and I decided to use acid based rust product on all the bare metal areas, then removed it with a solution of water and baking soda, so I could use your metal wash product, and then spray your epoxy primer tomorrow. Even in the Arizona sun it developed a flash coating of rust on about 50% of the area within two to five minutes, before I could dry it and apply the metal wash.What should I use to remove the rust at this point? Quick and easy if possible. Thanks
