Final primer coat
  • #35120
    alini
    I used Contour Poly Primer and Filler to get a good base on the car. Im running a guide coat now and I am straight but I have hit metal and filler. The Contour primer lays very rough and I did my initial blocks of my other coats with 220 just go get the ‘texture’ down. For my final coats of primer, do I just thin it with 5% acetone or should I use another primer which is thinner to start to make my final sandings a bit quicker. trying to get paint on before the Vegas summer heat hits
