F150 project
Viewing 2 posts - 1 through 2 (of 2 total)
  • #35719
    I’m working on a 07 f150 that I’m converting into a Raptor. I have fiberglass bedsides, fenders, and hood. I’m trying to figure out what primer, sealer to use. I am a first time painter so I’m trying to get everything I will need. Would I be better using a expoxy primer or urethane [ATTACH]5188[/ATTACH]primer? How many gallons would a f150 take?
    #36277
    ScottC
    Keymaster
    Our Epoxy primer can be a great sealer/base primer to start your paint job. Then the urethane primer would be best to “block” the areas nice an laser straight. Though if these are new fiberglass parts you may not need the Urethane if you are happy with the look of the panel.
