I prepped my radiator support with Pre, wiped it with a tack cloth and proceeded to patch some areas with RE. The rest of the area I applied the primer and after waiting the suggested time, I sprayed light coats of the chassis black. While applying, it appeared to look like water droplets coming out of the can. Now, approximately five hours after applying, it looks like it has rained all over the support. Any ideas about what is causing this and what I should do? I’ve used these products before in the same way, with no problems. Thanks in advance!
