I’ve searched the product data sheets for the Rage and the Eastwood epoxy primer and have not come up with definitive minimum temperatures for use. I recall seeing 75 degrees in on place for the primer and 70 in another (nothing on the filler). There is no way I can get the garage up to 75 and would be lucky to get 70. Upper 60’s is more likely. Do you know the minimum temps for these two products. Thanks, Bob
