Epoxy Primer Flash Time
  • #35337
    dsbratton
    I have been using the Epoxy Primer in 70 degrees and have been pleased with the results following the directions provided… Now I will be spraying the primer in 70-80 degree range. I know the hotter, the shorter the flash time. So what is recommended for a flash time at 80 or at 75? How do I figure out what the flash time would be?
    Thanks!
