Kevin I am using a 2 part epoxy primer over bare metal. Ive heard that you need to lay down a couple of coats then fill with Mud where needed and I’ve also heard that you can do the mud work first then build with the primer I have already done som major fill and then sprayed the epoxy. Do I need to re do or am I OK. Secondly, what kind of paint can I put over epoxy, Laquers,enamels urethanes sing and multi stage?
Can anyone help before I waste $200.00 worth of primer.
