epoxy primer
- This topic has 0 replies, 1 voice, and was last updated 11 years, 3 months ago by .
Hey Kevin,
I painted trunk, hood, doors with Eastwood’s Epoxy primer. Came out great!
Realized that I have to do some small fiberglass filler on the trunk. After the filler has fully cured could I spray another coat of Epoxy over that, or should I use a primer surfacer/sealer instead. After that it’s onto the base coat.
What should I do/use to cover the filler + Epoxy before applying the urethane base coat?
