Engine Bay Preping
Posted: March 14, 2012 By: KNGRAGE
Home Forums Ask Eastwood Engine Bay Preping
  • #34218
    KNGRAGE
    I have done a a lot of research and needed some input on what I should order from EW.com.
    First off I am painting an engine bay, I have some rust in some of the seams and where the battery tray was located and a patch piece also needs to be welded in place. heres some pics of what I am talking about
    [ATTACH]3907[/ATTACH]
    [ATTACH]3908[/ATTACH]
    I will be removing all the factory seam seal and will apply new stuff.
    So far I have this in the shopping cart
    EW Brush on Seam Sealer Quart
    Spray Max Epoxy Primer aerosol
    Pre Painting Prep Aerosol 11 oz
    what else would be need to help remove rust, can I use the Rust Encapsulator, then epoxy primer, seam seal, epoxy primer over seam seal and then primer sealer. Or should I use a rust remover/dissolver, then epoxy primer.
    I also have some other questions that I needed to ask but I can wait until these are answered
