Hi, I have a ’69 Ford Mach 1 428 Cobra Jet that I want to eventually restore. It has rust in the panels that I want to stop from getting worse and spreading until I have the time and money to have it restored. Ultimately the rust will be cut out and replaced with new metal, but until then, I just don’t want the rust to progressively get worse as it may sit for a couple of more years.
What Eastwood products would be recommended for this? Also, I imaging I’ll need to strip the paint around these areas, correct? Is there a disc/wheel that you would recommend for a standard hand held drill?
Thanks.
