Hi,
Simple question(s), I’m using the 1/4 mile candy on my project and given I’m a nuby with regards to paint and body work I ordered two gallons. Should I mix the two gallons of paint together so there is no chance of a multi-color paint job? Also with regards to the final blocking of the primer. I’m using epoxy primer as the final seal coat, is 600 grit the proper grit before application of the topcoat? Thanks in advance
Anthony
