Just got this welder looks good. Set it up tried to weld with it, very low heat can’t get any penetration weld just sits on top of the metal. It’s only 1/8″ tried everything plugged it into the same plug i use for my air compressure (30amp 120v) clean ground, tried .030 wire .035 flux core. That was to thick for this welder. It’s hard to get a puddle going and if I do it’s a big fat weld, even if I turn it up all the way. Anyone having the same problem?? I Should have got a Lincoln 180!!!
