Alright, so i have a 95 chevy S10 i want to eventually paint with Hot Rod flatz Hugger Orange. I have some body work to do, about 4 dents, 2 major ones.
My bed is curently primed with some flat black Epoxy primer and the rest of the truck is factory paint.
Im wondering if this is right:
1)do body work and prime that small area with EW Epoxy Primer and Catalyst Kit Black(Item #51128 ZP)
2)once all body work is done an the clear coat is sanded down, hit the whole truck with Featherfill G2 Buff from EW(Item #19782 ZP), sand and repeat if needed.
3) Shoot the whole truck once more with same Epoxy Primer as in step one.
Now from here, can I leave the truck sit for a few months and drive it around, or does it need to be painted with the base right away?
the base is a single stage paint, so if i was able to let the truck sit and drive it around, would i need to sand down the epoxy before i spray the base?
I can shoot my base over the epoxy right?
and also, does the epoxy primer that i listed act as a good sealer or would i need to just apply a sealer for a uniform color?
what sealer would you recommend rather then the epoxy if i shoot the base on right away?
thanks alot, i know its alot of questions but i just want to do this right!! :confused:
