Do i need chassis black primer ?
- This topic has 0 replies, 1 voice, and was last updated 17 years ago by .
Hello, i have a 99 custom dodge dakota that i am working on. It has some very very slight rust on the surface of the welds and such on the frame. Here is what i was going to use.
Oxisolve to remove whatever is there, then use your PRE paint prep, then spray it with you Black RE. I want to top coat it your extreme chassis black satin. If i use the black Re, do i need to use the extreme chassis black primer ? Or can i go straight to the extreme chassis black topcoat ?
–chad
