I just finished painting some parts about a week ago with Eastwood diamond clear satin (aerosol). https://www.eastwood.com/diamond-clear-satin-set.html
I thought all was great, but after a week, I moved a couple parts on top of a cotton (textured) rag) and after a couple of hours I noticed the rag completely imprinted into the part. Upon further inspection, I find I can easily scratch the surface with a light drag of my fingernail.
What went wrong?
I sprayed about four coats, each with minimum of 15 mins between coats, and they were dry to the touch between coats. I’m pretty sure the temperature was about 70 degrees.
Any help?? is there any way to cure it at this point? I’ve tried a toaster oven with no success. I bought some 2K clear to see if it works better, but I don’t want to try it until I figure out went wrong with this.
