DeVillbis Starterline HVLP gun set-up
  • #33067
    grandville75
    Hi, I have several questions regarding Starterline HVLP gun setup. The instruction manual is very general and does not go into any detail.
    1. What psi do I set the compressor regulator?
    2. What psi should the gun regulator read when the trigger is depressed?
    3. The startline has an air adjust knob at the bottom of the handle. How is this set?
    The fluid adjust and fan adjust are not a problem to figure out.
    Thanks in advance for the help. I hate to waste expensive paint to perform “trial and error” set-ups
    Jimmy
