Datsunn 280Z painting plan
  • #36065
    kerrys914
    Here is my plan:
    Fall
    Sand car down with 80grit to remove old respray
    Sand down to metal where filler will be needed
    Apply filler where I can and get as close to flat as possible in this stage
    Apply epoxy primer on car (2 coats) over whole car
    Let car sit for the winter and work under it 🙂 until it warms up
    Spring
    Sand epoxy primer with 120grit
    Apply polyester primer 2-3 coats
    Guide coat the whole car
    Sand with 220grit
    Apply light weight filler
    Guide coat specific areas
    Sand with 320grit
    Add filler
    Sand with 400 grit
    Add base coat and clear… 🙂
