Who was it here that uses a vinyl cutter to create custom masks out of hi-temp tape?
Would you mind sharing the details of how you do it?
What cutter? What substrate material do you lay the tape on, so you can remove it and apply, after cutting?
Do you just lay up hi-temp tape on a substrate and feed it to the cutter like it was vinyl?
Has anyone ever tried just masking with typical vinyl decals? Do they burn up?
Anyone have any luck slightly over-lapping tape on wax paper or similar substrate, printing a silhouette design on an inkjet printer and then cutting out with an exacto knife and masking with it?
thanks in advance,
