Hi Kevin, in your product demo you are talking about the new contour polyester primer filler. Is this primer a “DIRECT TO METAL” Primer? I have have used simular poly like the Evercoat G2, it say’s it has excellent adhesion to bare metal, steel..etc. But if you read the fine print it say’s any bare metal spot more than 1″ diameter, you should use an epoxy. I always put down an epoxy on bare metal before any of the other 2k primers that I use. Is the Contour poly a direct to metal? Thanks Joedirt
