Kevin,
I have used the eastwood evolution gun for applying my poly high build primer and subsequent urethane primer.
I just purchased the EW Concours Pro with the 1.3mm fluid tip and will doing the base coat / clear coat with that set up. My air set up is 80 gal, 5 hp, with plenty of cfm, so I expect little to no issues. The primers I used with the EVo gun went on flawlessly. Good gun.
Do you have any advice for shooting the Concours Pro.
This is my first paint job and while my body work and prime came out better than expected I am a bit nervous with the bc/cc. As you know…..that stuff can be an expensive mistake.
Any advice would be much appreciated. I love the EW products.
Regards…………..Rags..
