Hello. I am a novice painter finishing a motorcycle. I bought the Eastwood mini Concours HVLP gun and sprayed the primer and base coat urethane successfully with the 1.0 mm tip. I’m moving on to clear coat next. Do I use the same tip? When would I use the included 0.5 mm tip? Any other gun tips for shooting clear coat?
So far I can highly recommend the Concours mini. The fan control knob is a little loose, but a drop of blue locktight fixed that up.
Thanks Eastwood!
