Clear coat cracking problem
  • #28802
    merlars
    Hello,
    I have a sporatic problem with clears applied over other colors of cured powder. Sometime, but not always, I get hairline “spider web” cracks in the clear. Its usually where there is a curve or angle in the part. It doesn’t seem to appear right away, but over the next few days after application. Does anyone know what might be causing this? Under cure? Over cure? To much heat? Not enough?
    Thank you……
