Clear coat
Viewing 2 posts - 1 through 2 (of 2 total)
  • #36227
    imported_Evan
    Hey Eastwood guys i recently finished painting my project and have some areas in the clear with dry spray. I’m wanting to sand the clear and do a couple more coats. What do you suggest I use for grit and wet or dry. Thanks in advance.
    #36272
    ScottC
    Keymaster
    You would want to check with the instructions for the clear to make sure you get the correct grit. Most clears would be around 800 grit. This will allow you flatten out any peel and get ready for a you next coats. To hopefully eliminate dry spray in the future try reducing your clear to help it flow out.
